Just bought an '96 Jeep Cherokee 4.0L HO manual transmission (AX-15).
Some background.
The Cherokee runs great and the odometer read @ 95,000k some weeks ago, when we bought it. It had one owner who provided records of oil changes. maintenance etc. Seems like it is in great shape, however there are a few, minor leaks.I have read where the rear main seal can be a common cause of leaks. I was told by the owner that the rear main seal had recently been changed. However when I read through the documentation he had been keeping the I found a dealer's work order stating the customer denied the main seal repair. So someone may have done the work but not the dealer. I also see receipts from AutoZone around the same date as what is on the dealers work order, for valve cover gaskets, so maybe he just replaced those instead.
Anyway, the one leak I am most concerned about is a drop of fluid dangling from the bottom of the bottom bolt on what I believe is the clutch plate housing. When I look directly up above the wet bolt, to the area where the oil pan and clutch housing meet I see this...
First question: Should a gap, as indicated by the space between the red arrowheads on the above pic, exist between the clutch housing and the oil pan?
If the gap should exist, could the fluid be dripping from the gap? Is this near where the rear main seal resides? Could this be clutch fluid?
If the gap should not exist, would I just use some RTV to seal it?
Some background.
