Ideas of what to do with a old Radiator
Greenspan
Los Angeles
I had a leaky radiator that I replaced recently. There was a minor pinhole leak in one of the fins, debated trying to spray it something or fix it for a while, but then just decided it would be easier to replace it.
I'm a bit of a tinkerer and now that it's replaced, I'm trying to think if there's something cool I could do with it. It's a pretty interesting piece of equipment, high volume heat exchanger. The leak was pretty minor so I think I could cut into the fins and cinch them off. Could probably make a pretty bad ass air-conditioner with some water and a fan, but I don't really need that.
Looking for ideas of what could be done with an old radiator other than just trashing it. Go!
Make a still.
I used an old large transmission cooler from a Ford truck. Mounted it in front of a 20 inch box fan and hooked up my air lines to it. Pretty efficient air dryer for the compressed air. Don't know if it ll work with an old radiator.
I second the still.
Or, you could make a swamp-cooler for a garage space- of course, you'd need a fan, and a way to circulate the water, but with a water pump and a belt run off the fan, you'd only have one device to power. Fill the system with ice, a fan with shroud to pull the air through a window, and put a tank below it to fill with ice. Couple radiator hoses, and you're done!
Jack
It would work in principle but not sure about CFMs.
A still??? Just drink some Ethylene glycol anti-freeze and be done with your life.
Old, dead, parts are perfect candidates for "how does it work" and failure analysis "who done-it" studies.
Me thinks you thinks that I am more serious than me thinks I am.
And of course the "can it be fixed; can I fix it".
Scrap yard pays out around $5 per hundred pounds. So you should be able to get about $0.42 for it.
I'd take it there.
Your scrap yard and mine pay a lot different.
For an aluminum core (after I strip off the tanks) I get about $5
For a brass unit (after stripping off the steel braces) I get about $15
My last radiator I have sitting waiting to be taken apart just to see how bad it really was inside. If I can clean and seal it back up it will sit in the parts bin as a backup(while I wait for a new one to ship if needed). If I can't at least I will know first hand what an xj rad looks like on the inside before it goes in the trash.
