i need help! QUICK!!!
thebluebuffalo
Kentucky
i'm right in the middle of removing the interion of my xj to get ready to rhino line the floor. everything is out except the sound dampening pad on the front of the floor pan, it goes up under the dash. what is the best way to get this out? i've seen three clips, which i have removed. but i've noticed that the pad is rather large and goes into some pretty tight spots. HELP!!!
you want the best or easiest way? easiest= razor blade
both i guess... how far up should i cut it?
