Phantom said:XJs came with 3 different width factory fender flares and two styles. So these might just be molded from the widest variant of the early style.
Am now wondering if that description is for the flares underneath the XJ ones or not?Boghog1 said:in the right hand colum it starts with the CJ8 next is the XJ flares and right after that is the 7" flares
ChuckstrPT said:Don't know the exact widths, but I do believe it's wider by about an inch or so? I just installed 2 on the front, and they are fully covering my tires, 265's, on stock 16x7's with 1.25 inch spacers. The stock TJ flares I've got for the rear are noticably narrower, and they aren't painted...hmmm
Ramsey said:if it is, cheaper uglier substitute for bushwhackers. If you gotta be legal it could come in handy.
Chero-King said:Huh? what are the 3 different widths and which ones come with which widths?(confusing, I know,) But anyways.... Every XJ I've seen has either had what looks to be the same flares except the new squares style ones....?
The flares I have mounted up front are from a Sahara, and look to be just about 5 inches from the metal to the outside edge of the flare. The stock replacements (TJ) flares I've not yet mounted look to be 3.5 inches wide.Gojeep said:Would you be so kind to measure the front flare width for us? They do taper so maybe above the middle of the wheel would be good.
I believe they were supposed to be 1" wider than the standard TJ flare so that seems about right. Thank you.ChuckstrPT said:The flares I have mounted up front are from a Sahara, and look to be just about 5 inches from the metal to the outside edge of the flare. The stock replacements (TJ) flares I've not yet mounted look to be 3.5 inches wide.
HTH
I got 2 new ones off this forum for $40 shipped, and 2 very used ones from my local club for $25.:wave:bobb said:Where's a good place to get rear TJ flares cheap, just Ebay? I've seen them around for about $30 each, anything cheaper new? BTW, the junkyards up here suck.
