bdahlg
- Waltham, MA
The purpose of a SYE is not soley to reduce vibes. By dropping the transfer case you are putting a huge strain on the motor mounts. After a while, you'll will have to replace them, along with the output bearing on the transfer case. If you read the whole thread, theres substantial knowledge and wisdom behind it.So dont listen to half of these guys sye at 3" LOL
You think people spend $200 on something that doesn't help? What happens if you bend your rearshaft on the trail? Or break a ujoint on the shaft? You have fluid everywhere and are left stranded. With a fixed output, it's swap in a junkyard one or remove and continue in front wheel drive.
Temp fix is fine with a drop, but I would invest in a SYE further down the road.
