I can't find my crank position sensor connector.
SBox87
Avondale, Az
Well, guys I'm stumped. I pulled the motor in my shitbox 2 years ago for a rebuild. Life got in the way and laziness I'm sure, well I finally have my motor rebuilt and waiting to be stabbed back in. Idon't really remember all of the details where everything went. I'm working off of wire lay memory. So, my conundrum is that I can't find my connector for the crank position sensor. ANYWHERE. All my research shows that it's up on the intake by the firewall. So, I made a trip to the junk yard and got an engine harness from the same year as mine, 87, but the harness I bought has 27 wires and my original harness has 25. Where else could the connector be wired?! I don't have any wires that are unaccounted for. Wth?
I have the engine out right now and I can't find the connector anywhere. It's not even wired in on the engine harness, where the pins should be on the main connector block, they're not there on the firewall side or the engine harness side. I picked a harness up from the junk yard that has the CPS connector and that's when I realized that the new harness has 2 more pins in the main connector block than the my connector block on the firewall has. I'm confused by this, big time.
db27b9f0-27f8-4be3-afd4-bd5aeb6903c6
On my '88, the CPS wires come out in the same spot as the MAP sensor. Note the colors of the wires. Purple with tracer and White with tracer.
Wasn't there a repair kit that wired the crank sensor direct to the the engine computer, bypassing the harness? As I recall, if that was installed, it was normal to clip the old connector off the harness.
I recall the TSB although mine still maintains the connectors.
I suppose if the OP (or prior owner) spliced the cps harnesses together bypassing the C101, that would account for the wire count difference. But that would mean the OP cut the harness when he pulled the motor.
Of course, 2 years is a long time to recall every detail.
