fnjeep314
- ridgecrest, CA
Ok well I am new to this board but I am on the JeepsUnlimited board and NAGCA. Well the great guy on those boards just cant answer my question(s).
OK to start off I have a 01 WJ (and I know that this is the XJ board), I have a 6in short arm lift with JKS arms and tera springs and addco sway bars and lots more. Anyway I have a D30 in the front and a D44A in the rear. I am currently in the process of doing a NV242 TC swap for the stock NV247(quadradrive). I hate QD. I am wanting to run manual locking hubs but the WJ has a 5X5 bolt pattern. Neither of the hub kits will work. One is a 5x4.5 and the other being 5x5.5(well you all know this). I was told that I could use the D30 high pinion from a (I think) 94 to 99 cherokee and still be able to use the WJ knuckles and brakes and calipers. Would I have to redrill the WJ rotors out to the 5x4.5 pattern? I am also wanting to run an ARB 30 spline locker with 4.56 gears. Also do any of you guys have any suggestions on doing anything with a D44A? I can use any help, please. From what I have seen there are not too many guys doing this kinda stuff to WJs so the info is kinda limited.
