Hybrid Cage Build With passengers in Mind!
Hi blondejoncherokee, I met you in sac when I bought that Detroit Tru-Trac from you many moons ago. You guys should plan a trip up this way and I'll show you around.
Trying tapatalk for some pics. Front axle bridge installed before sierrafest. So I don't have to worry about the 3 link stressing the dana 30 center section
Looks good Dude!
I just used tapatalk for the first time too today. works for pics.
Well I am healing up from hip replacement 3 weeks ago. It's really feeling good, moving around pretty good now. Been getting the garage set up. Made myself a new fab table. Got new welder and plasma cutter,etc.. feeling good so time to start working on the jeep. Wanted to change the rear speaker bar speakers to 6.5" from 5.25". Little trimming and the new JL speakers should be good...
Bought the table top from weldtables.com. nice product! You have to put it all together clamp it and weld it up. Then I built my own table bottom. I am super happy with the complete table setup. Gonna make a platform for my chop saw that will go into the 2" receivers on the legs.
That tablemis sick
Got my plasma table section made today. Has many 1/8 inch pieces that can be changed out when they get burnt up. I spaced them at 1.25 inch. Whole set up is mounted on 2 inch reciever hitch. Can slide it on my bench, on right front, left front, and sides if I want.
Thats a sick setup John!!!
Thanks guys... maybe I should never go back to work! I got another 1.5 weeks I think. The plasma table should work out killer. If you want to get fancy, you can add a water tray under plasma table... like magic no more sparks on your flip flops BlondeJon
That's a tasty bit of steel you got there John, Great work as always
Looks like the perfect size for the back of an xj too, steel floor with easy tool add ons for trail fixes. unstoppable
The table top is 4'x3'... I alost got smaller, I am so glad I didn't. I did purchase the 1 foot extension. Just need to build it.
Used up the last of my 1 gallon of white monstaliner. Been wanting to do this for a while. Did the cargo area, welded up some holes for lower plastic trim section, that's never going back in. Throw the carpet back in and forget about it.
That looks so clean. Very nice man.
That looks legit John!
