HP Dana 60
Gravesdiggerxj
1991 High Pinion Ford Kingpin Dana 60.
Complete hub to hub from an F-350.
It has all the leaf springs, swaybar, steering and trackbar still attached, all cleaned up, painted and ready to go if you're interested. It even has the slip yoke part of the driveshaft included to save you some money if you want to build a shaft.
4.10 gears.
It has everything you need to make it go under your truck and it's clean and ready to go. 100% complete hub to hub,
Imagine not spending a month with wire wheel, unbolting everything to clean it. This axle is ready to go and sweet.
It's pretty nearly perfect.
The calipers are on my bench getting some love.
Give me a call or text and we'll set something up.
