Paul S
NAXJA Member #103
- Woodland Hills, CA
Currie 9" shaved housing
63" WMS/WMS
Currie HP9 third with 4.88's & Detroit
Warn Axles with CTM's
Drive flanges with Warn covers
PMP Hi steer arms with 1 ton TRE's
Track bar & frame bracket with tight FK rod ends (TB & drag link line-up perfectly)
UCA with tight JJ & FK rod end (Currie 2" JJ could be used in place of rod end if preferred)
Bilstein 12" 7100's with digressive valving + modified upper JKS mounts
Stock pitman drillied for 1 ton DRE
6" RE coils (not pictured)
Bump stops & ACOS (modified)
Spindle nut scoket
Spares: Warn stub axle, Alloy USA inner short side, CTM, full set of TRE's, tie rod, Warn locking hub, wheel hub.
$2500.00
Paul
63" WMS/WMS
Spindle nut scoket
$2500.00
Paul
