How much diff oil in a D44 ?
Kejtar
PostMaster General
I got 2 quarts in (ok.. almost) and I'm not sure if I should be trying to squeeze a bit more in (I got 4" shims which move the fill hole down a bit).
Anyways, when I get time (next fluid change) I'm planning on drilling and tapping a fill hole to make things easier, but for now I do it the redneck way: jack the rear as high as my jackstands will support it and fill it up.
I put in slightly over 2....call it about 2.25 quarts when installing my rear last week.
I wouldn't describe filling by sight as redneck. My XJ has a D44 and the manual says to fill it to the height of the filler hole. I've seen other manuals describe checking the level with a finger and if it's low you fill it to the level of the hole. But those amounts are about right. Depends on the carrier too.
Eric@OA said:
I wouldn't describe filling by as redneck.
The redneck part comes from lifting the rear and putting it on the jackstands to offset the effects of the 4* shim.
In regards to the carrier, I have a detroit in there, which potentially takes up more room (volume) then the open carrier with spider gears.
Remi-
Just an idea...
I got a cover from a HP 44. The fill hole was a good 1 1/2" higher, hence more fluid in.
BillR said:
Remi-
Just an idea...
Was this from the front axle from a ForD ? I heard that this was true but I need someone to verify.
Wayne
The Ford HP44 (front) cover is thicker than an XJ rear, and has it's fill plug up higher.
Mine is a standard cover, but I try to 'overfill' it a half-pint or so since the kicked up pinion likes that. Parking nose down on a grade is my way.
