- WA state
An interesting phenomenon I found on my 95 and also on the 93 was that they failed without any leakage or cooling problems. The design, at least on the OEM ones, was such that when the bearing went bad, the impeller would rub on the inner wall of the pump, allowing only a little play but a lot of noise. Eventually the impeller chews away at the pump wall and the play gets bad enough to kill the seal, but it can take a while. I went for a good long time on the 95 thinking that the piston slap had gotten a bit worse, and found the bad pump only by feeling for it.
All of which is a warning to yank on the pulley every once in a while to catch wear before it catches you.
Well, I found out the semi-hard way, it was bad enough that it pushed the belt off and it got half-chewed up by the mech. fan.
