Matt S.
- Fresno, CA
So here is an slight update to the build, dont want to add to the old post because the links are no good any longer.
Its really a tech question because I need to make sure I have enough triangulation in my cage :laugh3:
Oh and
Before:
After:
What you think?! No goin back now. I did add B pillar gussets. I THINK that is all the tube work I have. Not including the rockers. See any NECESSARY things i should add?
I am trying to keep everything off the firewall, mainly because on the temp. So I moved the computer(s) to the cage. The dash will cover it all.
Here is how I mounted the computer(s)
Looks like tomorrow I ought to have the tach and the speedo in and working. As well as the switch panel mounted. Going to try to get the front axle under it too. Any questions?
Matt
This is a work in progress if you couldnt tell. The dash will be a all aluminum dash for the desert race look.
Just for laughs, at least for me. It shows the gussets too.
Oh and
Before:
After:
Matt
