paulhead
I overtighten $#!t
- where compton meets the water
My Yellow top is smoking/hissing. Maybe a bad batteyr? I bought it used.
The volt meter in the dash would be pegged too right?13-14 volts is good the next thing is to get the battery tested . the battery should not be smoking at that voltage .
13-14 volts. But doesn't the regulator back off once it's charged the battery? Or are they bad when they're putting too much out?
What's the voltage with the engine off? If it's under 11 volts, then I would suspect a shorted cell.
11.58 v , charging it's 14.4
