Stoney
- Citrus Heights
i don't like my crappy timing chain i never installed it right i don't thing or maybe it is a little losse or something? does anyone know if they make gear driven timing?
stoney
stoney
Bones said:I checked into the gear thing while building my motor, ended up that a gear drive was over $400 for the 4.0 if you could find it. I decided to go a true roller double roller chain with magnafluxed gears for about $150.
The 4.0 chain set uses steel gear teeth and isn't prone to failure in stock form, so I don't think that gear drives are anymore than bling for all but the ultimate race prepped mills.
Bones :skull1:
xjblaine said:"And don't forget, they are loud as heck. Straight cut gears = supercharger like sound, even at idle."
had a landcruiser, it used timing gears, no supercharger like sound....
MudDawg said:You would have one heck of a problem with side thrust issues on a helical gearset....get a double roller set thru mopar performance or from Hesco.
By the way, if any 2.5 owners see this... the chain and gear set for the 4.0 will work well in a 2.5 by deleting the chain tensioner and removing the slider from the camchain cover![]()
