John D
NAXJA Member # 788
- Rockford, Mi
20 bucks for stainless steel grill sheets from Lowes. I do not have pans under them because if it rains I run for cover anyway. My doors are off from May to November.
A slow walk through a big wrecking yard could be the answer.
i think the cowl hood is the best as the vacuum next to the windshield will pull out heat and there is no rain leak, it's only money.
Is there any aftermarket hood vent with drip pans?
I haven't seen a LeBaron in 10 years, much less LeBaron vents.
I think ebay has millions of them.
I don't know for a fact, but I was always told
1/ there is a vacuum about where the windshield meets the cowl or at the rear of the hood caused by the air flowing over the hood and up the windshield.
2/. The idea being to pull air through the radiator and get it out of the engine compartment.
3/. That is why hood scoops don't really cool much because the air they scoop prevents air from flowing through the radiator.
4/. For max cooling you want to pull air thru the radiator and then get it out of the engine compartment.
5/. If big hood vents help, just remove the hood for max cooling, just kidding.
6/. I have no real proof on this, just what I have herd and a few years of life.
I don't see any with drip pans, just cheap plastic vents
It puts out a LOT of heat, on a clam day, I can see heat waves coming out of it at the top of my line of sight of my windshield, a good 3' off the hood.
