homemade co2 setup
jeepdeepfreak said:
Ok tell me what you think of my idea.I'm thinking of using two 10 lb cylinders.One cylinder with a 150 psi fixed regulator to inflate tires and another 10 pounder with a 90 psi fixed regulator to run air tools.
Good idea?
It would be easier and cheaper to only have one tank and change the pressure some other way. But, on the other hand, the nice thing would be if one tank ran out, you'd still have another to use.
So I could see it either way.
DAryl
Where is a common place to buy an adjustable regulator?
I was just given this bottle, all it has is a main open/close valve, will that be enough?
