jeepfreak1020
- Thornton
So Ive got the Hobart 140, and something wrong. I put a new tip on it and it will weld great for about 6 3" welds. Then it like bogs down and the arc gets really small and the wire welds itself to the tip. So I pull it out with plyers, pull the wire out snip it and on we go again. Does the same thing. So I clean the tip really good and still. I have replaced the tip 3 or 4 times and it still does the same thing. Also slag is building up really quick and bad, more then normal. Im using flux core so Im use to slag, but this isent normal. Whats wrong? Im using 030 wire and an 030 tip.
Could my drive rollers be going bad or what do you guys think?
