Fuel pump wont work if your engine is the 96 as well its a single fuel line and internally regulated in 96. also i never figured the right was to wire the tail lights with the 96 steering column so the brake lights would intterupt the turn signal when its on i did go down to wal mart and get a trailer isolator box so they would work but i think the turn signal still stops in the back when i hit the brakes if your running the pre 96 column its a piece of cake the pin out will tell yoou what wire to use off the colum harness for the brake lights to work right with the turn signals on.
