SharkXJ
NAXJA Member #1177
- San Jose, CA
Hey guys -
2001 with 140k and stock motor. As of September it is has been my 2nd car and gets driven every so often. Just took it to Hollister over turkey day weekend. Nothing hard core but did play in the mud quite a bit. It was raining hard today so I decided to drive it to work (50 miles one way).
Drove to work today, and had no problems. Went out about 3 hours later to get some lunch and the Jeep won't start. No Crank Nothin. I check the battery voltage = Fine. Checked the main grounds - fine.
Here's the abslolute weird part - I open the door - all lights that should come on - come on, I put the key in and turn to on, lights are on, then I try to start it, I hear a click and then the dome light dims and all the lights go out. I will leave the key in and about 5 to 10 minutes later, the lights come back on. I then try to start again and get the same thing.
I removed all accessory items (lights and Winch) from the battery just to make sure there isn't a short. I also pulled the relay cover and all of the fuses and relays are dry.
Maybe some mud / water got onto something that I am missing?
So at this point I am absolutely clueless. I don't know electrical very well so any and all help would be most welcome.
THANKS!!!!
THANKS!!!!
