Are you sure swaybar is 31mm?
What are your size options for purchase? Something close but smaller than will squish enough to work.
Thanks for the interest Tim. Well, I am a bit embarrassed. These old eyes ain't what the used to be......whenever i crawl
under anything to take a measurement I have always grabbed my trusty vernier calipers because they are bulletproof
and grime can be cleaned out easily. Needless to say, all those lines are now blurry so I finally went with my Mitutoyo
digitals and low and behold it's a 26mm bar. On another note, I just replaced the radiator and had to cut the coolant
lines for removal. Now I can't detach the remains of the upper hard line from the quick disconnect near the harmonic
balancer. I had intended to replace the damaged coolant lines anyway but found that the fittings on the trans are
covered in about an inch of oil and road dirt ( this is a new purchase from an old friend and supposedly a newish
long block). Turns out he's almost as old as me, but no longer does his own maintenance and it shows. Now my
best solution is to have the undercarriage steam cleaned, but to get it back on the road I need to find out what
size flared fitting nut to use as well as the taper specs (37* v. 45*). At this stage, I begin to wonder why I need
another 4x4, after all I used to wander all over the Anza-Borrego Desert and mountains east of San Diego in
a '64 2WD Dodge Van. Sorry for the missive, but as one of my grandsons used to say, "I am frustrate!"
