Help with Raptor Liner
I used herculiner....the tape should come off pretty easy up to a few a days (depends on how many coats your going to lay down) otherwise just use a razor blade. Worked for me.
Raptor lined my buddies TJ, we did 3 coats waiting the recommended hour(?) between coats, and left the tape till we were done with the third coat, then removed it. Worked fine.
yup used painters tape too.
