old_man
- Loveland, Colorado
1997 Chrysler Concorde.
I don't actually own this car but hope you can help out a young couple with a problem. I am here in Frozen Hell working on a contract and a couple at the hotel couldn't get their car started. I helped jump start it. It is -5 degrees here. It cranked fine but it wouldn't fire. I grabbed my scanner and it said that the camshaft position sensor was bad. No biggie, I do those all the time in my Cherokee's.
He pulled the battery and took it inside overnight and put a trickle charger on it. When he went back to hook up the battery, he reversed the cables for probably 30 seconds. There was some smoke coming from behind the battery, in the region of the ECU. He got it unhooked and switched around. It cranks and has indicators on the dash, but it won't communicate with my scanner any more. I checked the fuses under the hood and all look fine.
I am hoping he fried a fusable link or something simple since they don't have much money. I can help them some with the $$$.
Is there something that normally gets fried in this situation? Being an electronics engineer, I figured it probably hosed the ECU, but I am hoping for something cheaper for them. Any input and help would be most appreciated.
The only good thing about working on a car in a frozen parking lot a thousand miles from home in Minnesota is that it isn't mine.
