I have the factory winch (which is a Ramsey model)...The cable was all tangled and looking kinda scary frankly so I removed it (left about 10" attached). The cable is held to the side of the spool with what looks like a mini u-bolt but with the nut side inaccessible. My question was does anyone know anything about how to replace this? and also can I simply bolt new cable to the small piece I left attached? thanks once again :guitar:
No you need to replace the whole cable. If you try to use a u-bolt type setup to graft in a new cable, you'll end up cutting up the new cable where it overlays the u-bolt.
Not sure which Ramsey you have, I've never ween the kind of cable retention setup you're describing.
