HELP! re1462 leaf springs too short?
99xjache
NAXJA Member #1289
Im trying to install new leaf springs on my 99 it seems to me that the springs are too short eye to eye to install with the stock shackles. Am I doing something wrong or did I get the wrong junk?
youll have to bend the spring to reach, i used a block of wood, about 12" from the shackle end of the spring, inbetween the spring and frame, jack the center of the spring up....
Yea, you're REALLY gunna have to tug at the spring to get it in place with the shackle. Try to get someone to help you pull it back, then you put in the bolt.
Shoot, I did another search and found that I really cant use these these springs with the stock shackles. I need to install the 1.25"/1.5" lift shackles.
Looks like I'm goin 6"!
Well, I told my local off road shop I was trying to get 4.5" back in the rear springs, without blocks, and they sold me these. I should have done more research before going in. I may exchange them for the 1463 springs and the shackles to try and keep the rear @4.5". I dont want to go much higher than that.
My Rubicon 3.5" Leaf Springs gave me 6" with stock shackles. After a year and a few wheeling trips they were still hat 5"............ :lecture:
That's funny, they work just fine on my jeep with stock shackles. Weird.
Don't believe everything you read. Sure, newer 1462's flex better with longer shackles, but if you go out and break them in, they will flex just fine. Besides, if you add an RE 1.25" shackle, you'll get 7.5" of lift in the rear to start.
thanks again guys, got em in. Lots of tweakin and cussin but their in. The next order of business is SYE install. Doing that over the wkend. Ill post pics whenever Im allowed to.
