smokinall4
- OR
How do i test the CPS with the volt meter?
guess i will have to buy a wobble joint.... Anyone know the size of the bolts?
I have a drop on my t case, so i can reach mine easy..Use a jack to lower the t case about a 1" or 2", then it is easy to get to the bolts
my 1990 was doing the same thing check ur pressure should be like 30 psi or more if not replace it
7/16" I believe, careful you don't drop the bolts in the hole. Buy an extension with the wobble end on it. Here's a nice writeup that Marcus did.
http://go.jeep-xj.info/HowtoCPSchange.htm
The bolts thread into the bellhousing, making them metric (I believe, anyways) - I used an 11mm.
7/16 is just a hair over 11mm so it should work fine, these are low torque fasteners.
... have you actually tested the CPS or are you just throwing more sensors and money at it?
