RWKHausSupply
- yorba linda, Cali
Ok well I have done the following.
Bought a 90, 4.0, AW4, motor had a rod bearing missing and bad off.
After motor replacment it runs great cold and then after it warms up, about 90% of the time when stopped and tring to take off at a med pedel it will back fire very lightly and not want to go. Once moving it feels as strong as a 90 should I would think.
I have tested EGR and even discon. it and same issue.
I have removed all non-essintial vac lines and plugged ports, same issue.
I have spreyed down the entire upper area of the int man with break and parts cleaner looking for a vac leak, no changes in idle.
I have tried Everything I can think off really.
NOW..
Anyone in so cali that can find the issue I will pay a fair fee to, if they can find the issue. I checked the distrib and the shaft has no play. The only thing I can think off is the manual air adjustment idle screw. It was all the way in when I got it and it would not idle right after the new motor, so I opened it up some and it idled fine. But now with the ALL the new parts I think that was something else and now that that screw may be causing a rich or lean off idle issue??
Please anyone help.. I am in to this way to deep with new parts and $$
Oh ANYONE that has a renix 4.0 that can count the number of turns that it takes to close (clockwise) the manual screw on Throttle body on the drivers side I WILL be in debt to ya... It wouldnt cause any issiue for ya if you just counted the turns in then just returned to that many out. Please.....
OR anyone have a TB from a renix that has not been tampered with? I will buy it from ya. Let me know..
HELP! I need to move on to the rear end adn gears and cage but not till this is resolved.
- Replaced long block with reman. with a build sheet and run spec of all the vitals.
- Replaced injectors with reman ones that had a spec sheet, all look great
- replaced TPS set to .335 at idle and 4.2 at full throttle
- replaced MAP
- replaced Ign Coil
- replaced fuel pres. reg.
- replaced O2 sensor
- replaced cap rotor and wires and pluds
- replaced intank air temp sensor
- replaced ECU (same results from both)
- replaced the idle air control valve
- I have removed the TB and removed all sensors and throughly cleaned it.
NOW..
