Dewidge said:
I should be able to give you a hand on the 22nd.
SolarBell said:
I might be available the 22nd as well.
It shall be so!!!
I have asked Michelle to be here by 09:00. I will supply sammiches from
D'Deli, for lunch. No beer (or other alcoholic beverages) will be consumed until the work is done, and the Jeep passes Q.A.
If Doug and Gary
DO make it for this work day, there is still room to stuff a couple more bodies into the shop.
Scope of work:
Replace calipers and rotors, inspect front suspension, steering, and U-Joints.
Replace and adjust parking brake mechanism.
Flush cooling system, replace thermostat, inspect remainder of cooling system.
Inspect rear suspension.
Check fluid levels in front and rear diffs, transmission, transfer case.
Inspect spark plugs, cap, rotor, and wires.
Look for anything else that may fall off the Jeep and impair its function.
Let me know if you are interested in helping out!
