aplatz
- Frederick, MD.
What is the cause of this? High miledge, excessive heat from over heating? Is this a item that should be replaced before it fails? If so at whar miledge os recommended? When replacing the serp. belt, what are the tell tale symptoms? Excessive wobble, misalignment of the pulleys?
