Andrew T
- Houston, TX
I have a 2001 XJ with D30 front and 8.25 rear. I'm wanting to install lockers, but not sure which way to go. I know I will eventually re-gear, but I'm not ready to yet.
This has left me looking at the powertrax no slip and aussie lockers. A buddy that does a lot with toyota stuff said the aussie lockers are a bit stronger than the powertrax. They're also significantly cheaper.
Which do you guys recommend? This isn't normally a daily driver, but does get driven on the road. Should I do an aussie up front and spend the extra cash in the rear for the powertrax since it's supposed to have better road manners?
Thanks in advance!
Thanks in advance!
