{help} 4.5" lift, short arms hitting spring plate
Drop brackets will give you more up travel as well. Would move those transmission lines up higher.
On mine on extreme flex the upper control arm has touched the oil pan flange.
Try bump stopping correctly.
I got the rough country drop brackets but now my driver side coil rubs like every time i turn a corner or hit a bump. Yes the control arms are at the right lengths as suggested by the instructions from the bracket kit. but the coil still rubs on the track bar bracket. i also tried shortening the driver side arms by about 1/2 inch top and bottom to try to pull the coil rearward a bit but it still rubs, a little less however. not sure why it never rubbed before and all the sudden rubs now
yeah I had that problem on my zj, do you have an adjustable track bar? If so you can adjust it away from the track bar bracket....
