CanMan
- Lake Tapps, WA
I have to admit to kind of missing the old one.
-----Matt-----
Me too. And I havent even drove the new one.
Ill miss the stick as well.
-----Matt-----
For suspension, do the RE 4.5 with Bilstein 5125 shocks and never look at your suspension again.
As far as wheeling goes, look into T-case, and gas tank skids and also...buy rock sliders (they get used a lot in the PNW). Good luck with your rig, sounds like your on the right track.
~Scott
P.S. I have an '89 with a RC 3" lift (bastarded it to 4") with bilsteins up front, and full armor...if I could have done it again, I'd a done RE 4.5 with bilsteins and an SYE.
This is exactly the sort of thing I'm looking to hear. Thanks for the advice. What tires are you running with that setup? can you clear 33's? I guess I'm not entirely set that I need 33's, just seems that it's kinda minimum-ante' for some trails I've run with friends in the past. Or at least it makes things ALOT easier so you can worry about the scaier stuff.
I'm actually looking at picking up rockrails at the same time as my lift for sure, if not making my own. Definately don't want to pin a door shut my first time out... perhaps I'll hookup with some of the locals on sunday up towards north bend there and see what theirs are made of and how and perhaps try to fab some up myself as my first homebrew project.
AJ's makes some pretty durn good rock rails based on the feedback around here, if you don't want to take the time and effort to build a pair.
And yes, 33"s will easily clear with 4.5" lift, they'll clear with a little wheelwell trimming at 3.5" lift.
I noticed that about the extras with the 4.5" lift, all things I would likely order anyways, was almost considering doing the 4.5 kit with shorter springs and no drop shackle, but who am I kidding, I'm sure I can make use of an extra inch.
Right now I'm working out picking up some lightly used tires as well as looking into getting setup with locked and geared burlier axles. The lift kit'll be ordered early next week I think. YAY newtoys! the rails I might try to build just 'cause I've got a friend with a bicycle framebuilding company who owes me some favors and money saved on essentials is money for other goodies...
I certainly didn't expect it. There is good to be said for both, but with the role it fills for me, the old body is just as good, if not better.So Matt, Eli, and I have gone from old body style to new and miss the old. Glad I'm not the only one.
If I were to start over again with a retail kit I would go with the RE 4.5" over the 3.5" it comes with a lot more than the 3.5" kit.
The 4.5" kit comes with upper and lower CAs, Extended front brake hoses, and a trackbar. Pretty good for a little less than 300 more
I noticed that about the extras with the 4.5" lift, all things I would likely order anyways, was almost considering doing the 4.5 kit with shorter springs and no drop shackle, but who am I kidding, I'm sure I can make use of an extra inch.![]()
