JohnX
Sarge
- Williams AZ
Has anyone used the Comanche specific full length add a leafs from hell creek? I'm only looking for one-two inches of lift and my pinion angle is already perfect, so i'm not looking for a shackle change.
that's a nice looking MJ.
Do you ever put a load in the bed? Trailer? And are you happy with how it rides on and off road?
Pretty sure these are the same ones from rancho. Anyway, I like how it rides, so i'm gonna make some new mounts and shackles to get the height I want and move the axle back an inch or so.
Yep, thats where i'm at right now. I cut out some new front leaf mounts and will be lowering them 1.5" and moving rearward 1". Then the rear is going to get a longer shackle and reinforced mounts.check with Brian @ hdoffroadenineering.
the bottom half of a XJ relocation kit will give you the extra inch or 2 you want, and give you shackle angle options. Should be able to weld it right to the bottom of th framerail.
Well, after all that... The mainspring has flexed backwards against the add a leaf. So all in all it got me through 1 wheeling trip. Time to replace the whole pack.![]()
