Heim joint rattle
The Rough Country marketing team found my YouTube video and they were not pleased.
They tracked down my email address online and offered to send a replacement. The new one is supposed to be heat treated and should fix the "occasional issue." OK.
Tell them you'll only run it if they send you the 14$ for the FK one you already bought.
Sell it!
I found this crazy joint that doesn't need lube, doesn't rattle, absorbs a lot of road noise and lasts like 100K miles!
It's called a bushing
Smartassedness aside - I think a lot of discrepancy that people come across with heim vs heim battles may be that one guy went hard joints on both sides, another went heim + poly, another still went heim + rubber. Just a theory.
Also... TREs & Bushings last hella long in all sorts of conditions. Proven again and again. Aside from it being easier to drill a hole than to ream one, what's the fascination with heims?
i wouldnt say all sorts of conditions....
TRE's are good for light duty stuff, but won't hold up to high loads/impact that you'll see in abusive wheeling. my last TRE's (1 tons) lasted maybe a couple months.
has anything you've run lasted more than a couple months :roflmao:
