Heat soak or normal
chickenbot
frisco
93 4.0l ax15 np231
Under normal driving conditions it gets hard to shift.. I just chalk it up to age and trans just needs to be rebuilt. I do notice that when everything is cold it shifts fine but as everything heats up it gets harder to shift. How hot should the trans get under normal driving conditions?
Heat related, sure, but it's not what we talk about as heat soak -- Heat soak in a XJ is when the fuel turns from liquid to vapor in the fuel rail or injectors causing a very rough running condition -- I had it so bad in a 96 that it would stop running altogether
And no, what you are experiencing is not normal for any of my jeeps
