header fit
Well that's good to know. I'm not going to have enough room on the header to put the egr pipe, do you think i can get away with running both the pipe and the o2 sensor on the down pipe? Maybe use a piece of flexible pipe. Could brass potentially handle the heat
Nvm on the brass, gotta find something flexible and high heat resistant
Old (what's that weird pipe thing sticking off the main tube)(not the egr or o2 sensor bungs)
New ish edelbrock Shorty header
Was thinking running the tube like this maybe
It looks like i may need to get an ho down pipe
O2 sensor for sure. I've done that.
If i switch to the ho downpipe, it will already have a hole for the o2, but i will have to do some creative bending for the egr
I just have header downpipe cat muffler and a turndown. Nothing in the rear, the part that hooks to the xmember is different but i have an entire rear exhaust from my 90xj in my shed that might work, sawzall and a welder should fix the rest
