i guess. i have my ipod in my glove box (ipod cable) and the aux in (from the rear of the HU) coming up into my ashtray where my phone usually lives.
Understood. And that may be what I end up doing as well, but as I'm also looking at this in part as a component of a larger plan to (effectively) build in USB infrastructure, I'm keen to keep to USB if possible as a one-shot solution.
I have used a lot of audio to usb adapters, but the thing most people don't really realize is that the adapter is actually a sound card and has to be set up and recognized by the computer.
Correct, this is my understanding as well. However:
I don't ever remember seeing an actual protocol for straight audio over usb.
It's entirely possible that I'm not completely understanding the documents I've been going through, but my understanding is that it's possible to send data frames over USB that are specifically identified as containing audio. Further to that:
I have seen the protocol that allows the operating system to use the usb adapter as a sound card. That being said, you head unit would have to behave like a mother board and have drivers loaded.
This is where I'm thinking that the drivers may be necessary: if the standard for moving the audio frames over the wire only specifies the frame format but not the format of the data in the frames, then it would make sense that drivers may be needed to interpret the data inside the frame (though it seems like something that could potentially be handled by an application as well).
Remember that I'm just concerned with moving the audio stream over USB in a format that the head unit can understand when it receives it - the processing of the audio will already have been done when it hits the wire, so all that needs to happen is that the phone squirts a frame to the head unit, the head unit strips the frame from the data within it, and then plays that data as digital audio.
What I'm hoping for is a lowest-common-denominator method of achieving this that both devices support, and from the reading that I've done it looks like there may be something there that covers this. However, I really need to dig into it a bit more deeply to get a decent grasp on it; failing that, there may be something out there that can put my phone into an iPod simulation mode as far as audio connectivity and output is concerned, which would make this a possibility on stock iPod interfaces.
