Harmonic Balancer seal
the radiator isnt in the way. wtfmatta you? :doh:you got stock in prestone?!? why mess with coolant if its not in the way?
like i said, did it twice in 2 weeks, including timing chain.
pulling the rad is much easier than pulling the front axle.
and if you know what you are doing it is pretty easy to save and re-use your coolant... I would have done it if mine didn't need changing anyway.
pulling the Rad doesn't require jackstands, or removing brake calipers, or driveshafts or control arms, or steering links, or track bars, or shocks and springs,
it requires a few screws and a few hoses being disconnected. but if you want to work smarter not harder be my guest.
