jakehobbs
- Salt Lake City
97, 4.0, Auto, 135K, 4WD
Long time lurker, first time poster. I have a 97 Sport that I have been having random starting problems with. I am no master mechanic but I like to tackle most of the issues on the jeep myself. This one has been plaguing me so I think I am ready to seek some advice from a professional to at least rule out some of the possible problem causers.
When I go to crank the motor over it will just turn and turn until I press on the gas pedal. It will run rough for a few seconds and then its fine. The temp gauge is also not registering which leads me to believe that the thermostat is sticking open, this also causes it to idle as if the motor was cold. I checked the fuel rail and there is pressure, not sure how much though since I didn't use a gauge. Over the past year or so I have replaced every part of the cooling system including the coolant temp sensor and two different thermostats. Thats why I am stumped on why it is not registering on the dash.
So based on the above, and info from searching the forum, I have it narrowed down to the following:
-Bad CPS
-Bad Fuel Pump
-Bad Coolant Temp Sensor
-Faulty Thermostat
Any advice? Thanks in advance.
-Bad CPS
-Bad Fuel Pump
-Faulty Thermostat
