s7tech
- Orange, California
Ok, I really have searched. My problem is on my hack and tap on my 231 the 4 bolt flange that the driveshaft bolts to is loose and I believe it is causing me to have so DL vibs. I pulled the driveshaft and the bolt is very tight, I could not tighten or loosen it. It probably has .090 or an 1/8 of an inch play. Is it normal to have this much play with a hack and tap or is something wrong. Thanks
