lorax81
- St. Helens Orrygun
what is a NOID light and i will pick one up tomorrow. i will double check the grounds at the dipstick. as far as the dist i never took the cap off i just unbolted it staight out of the old block and is in the same position as my other 90 xj. that is what is so damn confusing every thing is hooked up exactly like my running xj. when i take out the plugs they are soaked with gas telling me that the injectors are letting fuel in i just cant verify that they are squirting at the right time. that is why i need a way to identify the injector wires.
the rig wont even sputter it just cranks and cranks with no fire
Well, 120 in each cylinder, you have a strong blue spark at all cylinders, and you have fuel pressure that is correct.
So, even though you have fuel pressure, is the ECU firing the injectors? Grab a NOID light and check for injector firing--test lights and multimeters won't do it. Or, you can spray ether into the intake and if it fires you will know it is the fuel injection.
Those grounds at the dipstick tube are CRITICAL. They are the grounds for the ignition control module, the ECU, and the 02 sensor.
The synch sensor in the distributor sends signals to the ECU along with the CPS/CKP that will determine the firing duration of the injectors.
Those are a few ideas for things to check.
Just to stress something simple, being 180 out on the timing has caused many XJ owners to rip out large patches of their hair. When you say firing at TDC--that is TDC on the compression stroke, i.e., the stroke where both valves are closed and if the spark plug is out there is a great force of air from the cylinder?
Not a dis, it has happened to others so I gotta ask.
