- Andover, VT
Great job grinding it out man. I give you props for tackling this yourself when you didn't have the know-how going into it. Sure, you've now dealt with the consequences a couple times, but nobody will ever be able to take this knowledge away from you.
Do you have a thread where your other gear setups were documented? I'd be curious to see patterns and hear specs of the setups you did prior that led to failure.
How did the 1st set fail? I don't remember seeing that.
That Yukon manual is neat, but BOY do some of those patterns in the "acceptable" category look awfully sub-ideal. Not that I've ever done gears or have any experience with what works and what doesn't... Just an armchair wrencher
