Daedalus454
- Simi Valley, CA
I had 4.56 gears put in last week, and since then, in addition to the driveline vibe issues, I have had a strange and rather bad-sounding noise from the rear diff. It's very low-pitched, I can feel it in the floorboards and the steering wheel, and it occurs when I go from accelerating to coasting. When I am accelerating it's quiet, and when I am coasting it's quiet, it only makes noise during the second or two when I transition.
With all four wheels on jackstands, with the XJ running and in gear, the passenger tire spins and the driver's tire remains motionless. When I hit the gas, the grinding noise occurs sporadically, and each time it does, the driver's wheel rotates a little.
I examined my side and spider gears, and it looks like my spider gears are worn out, but is that likely to cause a problem like this? It was fine until I regeared, but the carrier and spider gears shouldn't be turning any faster than they were before at the same speed, correct?
