Ok I've searched hi and low and nothing matches quite what I've got going on. I'm getting a grinding noise when I turn either way in 4wd hi or low only. Every thing is smooth in 2wd. I've got a posi lock on it, if I run the transfer case in 4 hi or low it grinds with the axle unlocked. If I lock the axle with it in 2wd it grinds when turning. I jacked it up and theres no play in the front drive shaft, but there does seem to be play before the spider gears engage when spinning one tire, about 3 inches before the other tire spins is that normal? I'm leaning towards spider gears but wanted other opions before I starting yanking it apart. I just got this thing a few weeks ago and it wasn't takin care of very well, still finding things that need fixin.
89 cherokee 3in. procomp lift 33/12.50 bfg's Auto
1 in. tranny drop
1 in. tranny drop
