Grimm proof d30 housing, 1-ton steering
GrimmJeeper
Gardena, CA
This housing is built about as far as you can go with a d30. needs a new pinion seal and one shaft seal. included are 3.55 gears, a ring gear guard that goes over the stock diff cover, the knuckles, a well used JCR 1-ton OTK steering setup, and the pitman arm that is already reamed for the 1-ton TRE. less than 500 miles on the ball joints and UCA bushings. housing is powdercoated and set up for coilovers and bypasses, but it would be easy enough to grind off the coating and add coil buckets if thats what you want. sleeved with .250 wall DOM, plated trussed and gusseted everywhere possible. This housing was built by Curt LeDuc.
pics (steering not shown):
I'd like to see $500 for the whole setup. i'll split the knuckles, pitman arm, and steering setup for $100 and the housing for $450.
prices are negotiable.
f150 beams and a 4 linked rear are on the table now. I'm done f'ing around it's time to go big or go home :D
my drop brackets and control arms will be up for sale soon as well.
DIBS on the DB's. I finished Amies jeep and it has terrible death wobble, need to do everything I can to get geometry right now.
PM me as soon as they're ready.
Wish I had the cash, I have coil buckets waiting to be welded on my current axle.
Not to derail the thread but I have a unused pair of coil buckets if you need them tone?
Just to clarify when I say well used 1 ton steering I just mean the links have some rock rash, the tre's themselves are good as new. Pretty sure I have a spare for one of them as well.
Bump, need cash to fund the new build! 100 for the steering and 300 for the axle. Payment plans accepted.
For 600 I'll sell the steering and axle together along with the whole bare chassis set up to run coilovers, front end plated with tmr stiffeners. Just add coilovers and finish the cage, drop your drivetrain in and go!
