offroadordnance
- Florida
After work someone noticed a green puddle under the Jeep. Popped the hood and it's running down the lower rad hose. It's not leaking from rubbing on the steering box it's much higher right near the water pump inlet. I don't know where the weep hole is or where the 4.0L water pumps leak from. It's pouring rain out and I'm wondering if I should try to swap the hose out tommorrow where it sits or tow it to my shop and change the pump. The pump body is dry as far as I can tell. Any ideas would be appreciated.
