Got a lawn mower grass chute?
ZacSquatch
Fairbanks, AK
Boo-Yaa...
Found one in our shed, and I got a light bulb idea... Upgrade my "cold air" intake...
Originaly just had a cold air tube and had it mounted with a cone filter on the end...
Now I have my filter in the grass chute and I have it pointed so air that comes through the rad. and next to it. Eleminates a lot of hot engine air.
GHETTO AND LOVIN IT!!!
anyone ever think of doing this?
i was thinking of cutting a hole there, if you look behind the valence it's pretty much a straight shot to the engine bay. If you could fab up some sort of "chute" you could get a pretty intense flow of air going through at the top of the front fascia.
Then if you go through lots of water or mud then there is also a straight shot into your intake. Or if your cruising down dirt roads behind someone you just getting all sorts of dust in there. I guess if you just do rocks than it would be good. But at least the other was it has to work to get in there.
ZacSquatch said:
Boo-Yaa...
You might be a REDNECK if ya start using lawnmower parts on your Jeep!!:D Nice one Zac Squatch yet another inovative idea!!:thumbup:
Umm.. I prefer Appalachian American.....
:laugh3: OK, AA it is!!:D
WTF?? I beleive the filter does that... same as any stock filter would... this even eliminates a lot of splash from underneith that I was experiencing.
No he was talking about what I posted... I wasn't saying ram air straight shot. something like this from the side. It would just force a lot of cool air into the engine bay.
ya i wasnt talking about your mower deal. I was talking about having the intake rite in front. Was just sayin that it would open it up to get a lot nore junk in there than you would want.
As for the mower deal, hey it would be a heat shield and its a good idea. The bigger trucks such as silverado's, have a box set up around the actual cone to act as the same heat deflecting shield.
OK?
OK?
My bad..
And I'm still debating on the hi lift mount
Rehab is for quitters...
I used a 2.5 galon water jug for my cold air scoop. Same kind of principal you have. It keeps the hot radiator air off the filter.
tigerShark said:
the ram-air thing would probably see the best results on the street.
yeah, you could always make a cool jet fighter engine plug type thing to stuff in it when you went off roading.
I was even thinking about an afterburner and a ejecting canopy as well
I had the same deal with my Mr Fusion reactor.. gas company blew up my ride because I wasnt buying gas.
