Good Stuff For Sale.
RoyalXJ
NEW USA gear 4:88s (hp30 c8.25) with install kits and Yukon 373+ carrier $400
HP30 with Artec truss, Artec LCA mounts and Riot Fab Works OTA TB bracket all welded on. Coil buckets are chopped and boxed. Comes with Artec inner c braces $250
29 spline 8.25 3:55 gears. Shaved housing. No brakes. $75
Boostwerks DIY steering box brace kit $120
KJ rear disc swap. (Direct bolt on) backing plates with no e brake, calipers, new ceramic pads, new centric premium rotors, new brake hoses, back plate studs, wheel studs, ZJ proportioning valve $300
NEW rubicon express hd track bar bracket $50
NEW rubicon express track bar brace $50
NEW Dana 30 27spline Aussie locker $175
2- Ruff Stuff 3/4 heims and piece of 1.5" .250" wall dom for a track bar. $40
2- c8.25 Ten Factory alloy shafts 27 spline $120
Dang that IS some food stuff.
Interested in the d30 Aussie locker. Also going to nacfest. Or ship?
Is the d30 complete or just the housing?
NEW USA gear 4:88s (HP30 C8.25) with complete install kits and Yukon 3:73+ carrier $400
HP30 with Artec truss ( driver side needs finishing), Artec LCA mounts and Riot Fab Works OTA TB bracket all welded on. Coil buckets are chopped and boxed. Comes with Artec inner c braces $175
29 spline 8.25 3:55 gears. Shaved housing. No brakes. $50
Boostwerks DIY steering box brace kit $120 -pending
KJ rear disc swap for C8.25. (Direct bolt on) backing plates with no e brake, calipers, new ceramic pads, new centric premium rotors, new brake hoses, back plate studs, longer wheel studs, ZJ proportioning valve $250
No idea yet on nacfest? Pretty interested in the d30
Boo you suck
