DenLip
- Southwest PA
scoobyxj said:mine is a 00 my T/C lever rattles a little, the pass. side window swich is tempermential, likes to lope a little when i first start it gose away after about 10 seconds [im not a crank and go driver so it dosnt bother me],and the driver side speaker is possesed. havent had any trouble out of the roters yet with 60k on her.
Man. I wish this topic hadn't come up. I guess I've had more problems than I remembered!!
My T/C was leaking from the rear seal right from the get-go (had the dealer
fix at around 3300 miles/1 month). Mine has a bit of a lumpy idle after a
cold start as well. Thankfully, I'm generally easy on brakes... and at 54k
mine are still stock pads all around, and no warp. No speaker problems...
but my stock speakers were replaced when she was essentially new - I
wonder if it's the speakers themselves that are the problem, rather than
wiring? My front diff is leaking a bit around the pinion, but I blame that
on the dealer overfilling it when I had the fluids changed back at 35k.
(After 20k of driving with the slow drip, the fluid STILL isn't down to the
"1/2-inch below the hole" that's recommended.)
Den
