GM 14b 10.5" full float rear axle setup for XJ - spool chromoly shafts 5.38 etc.
RWKHausSupply
Removing a 14Bolt from Cherokee XJ, moving in to Currie F9 housing.
Housing will be available after Oct 15-17ish.
66ish WMS
Has:
*Ballistic Fab shave and cover (done by Currie and not a drip of leakage), has better ground clearance then a D44 or 9".
*TNT full top truss.
*U-Bolt Eliminators set for XJ width currently.
*tubes welded to center by Currie.
*Disc Brakes with all semi new bearings and pads etc, used for Glen Helen about 25 miles.
*Ruffstuff caliper brackets.
*5.38 Shaved gear set
*Yukon Steel Spool
*Yukon chromoly axles (like you really need em, but hey you cant break em.)
*1350 Yoke
with current hubs it is a 8lug and 66"wide. You can get alum hubs from Solid axle that are 5 or 6 lug and reduces the width 2.5-3".
Will include hub to hub, yoke to cover, including the brake lines and T hose.
1500$
Located in Yorba Linda CA
[email protected]
Re: GM 14b 10.5" full float rear axle setup for XJ - spool chromoly shafts 5.38 etc.
Huh?
the bottom bolts on the shocks (i cant see the top). they way they're facing...you dont ever time up teh shocks when you articulate the axle? if those heims go past their max radius (or whatever its called) and you're still articulating up or down, its going to be a load on the shaft of that axle, the heim, etc. just an observation is all....more so curious if you ever noticed any issues really.
*you dont ever BIND up the shocks i mean* really tired here....
and i meant a load on the shaft of the shock. FML i'm getting coffee...brb. lo.l
nope. everything was fine and has been like this for prerunning KOH, koh (the first 14 miles lol) and glen Helen, a few calico trips, a few BB trips, TDS a few times, etc...
nice. :)
finally got coffee in my hand. sorry about that robble up there. there's no edit button.
GLWS!
nice. :)
GLWS!
No problem.
And we did also test fit alot..
